I want to understand PostgreSql Database Schema for Codebeamer Requirements Management
Divyanshi
7-Bedrock
Hi There!
We are working on migration from IBM DNG to codebeamer.
For this, we are considering IBM DB2 to Codebeamer PostgreSQL database migration.
I want to understand database schema of codebeamer for requirements management.
Can anyone help in how I can identify tables and their correlations in PostgreSQL for codebeamer requirements management?
Even the slightest suggestion would help. Thanks 🙂
Divyanshi
We do not have a Codebeamer Support Community yet. You can contact the Codebeamer TechSupport team using the eSupport portal as well. Create a case and we are ready to help you: https://support.ptc.com/apps/case_logger_viewer/cs/auth/ssl/log
Andra
This topic has been moved from the "Codebeamer Ideas" to the "Codebeamer" forum due to its non-idea nature and in order to receive the visibility needed.
Catalina
PTC Community Moderator
PTC
