In V2.2.1.3, the Review Hub has a wrong base url
JR_12222956
Due to some reasons, our Codebeamer has separate internal and external network access addresses. After our Codebeamer was upgraded to V2.2.1.3, when we open the Review Hub, it consistently points to the internal network address and cannot adapt according to the browser's domain name. In the previous version V2.1.0.0, this issue did not exist. How can we make the Review Hub's address change dynamically?
Hi @JR_12222956 ,
Codebeamer 2.2 and onward feature a newly upgraded ReviewHub which leverages the Angular UI previously used for Codebeamer-X. Behind the scenes, this new UI references different functions and settings of the Codebeamer server than the legacy version.
In the 2.2 series specifically, the URL is actually set under System Admin -> Outgoing Email Connection. Please review the following article:
https://www.ptc.com/en/support/article/CS423575
Please let us know if this helps.
Thank you,
Tyler
PTC Technical Support
Hi @JR_12222956
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Best regards,
Catalina
PTC Community Moderator
PTC
Hi @JR_12222956 ,
Thank you,
Tyler
Hello @JR_12222956,
It looks like you have a response from a community member. If it helped you solve your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
