Only the head revisions of project artifacts and work or configuration items are exported.
RS_10914190
Dear Community,
I am looking for a way to use the export functionality in codebeamer to export a tracker item as a word document in a version other than the Head Version. An older version of the same item.
I saw in the documentation that there is a restriction that Only the head revisions of project artifacts and work or configuration items are exported, including comments, attachments, permissions, and associations, but without history.
Is there a way to bypass this from front end or back end using inbuilt classes in codebeamer?
Codebeamer Version: 2.0.0.1
It is possible to export a work item with a specific Word template.
Open the Exporting Items pane, and select "Items template with history" template on the bottom of the page.
Using this template during the export you'll have a History table about the changes on the item:
We do not have a Codebeamer Support Community yet. You can contact the Codebeamer TechSupport team using the eSupport portal as well. Create a case and we are ready to help you: https://support.ptc.com/apps/case_logger_viewer/cs/auth/ssl/log
Andra
This topic has been moved from the "Codebeamer Ideas" to the "Codebeamer" forum due to its non-idea nature and in order to receive the visibility needed.
Catalina
PTC Community Moderator
PTC
Survey Now Live!
Codebeamer Community: we're listening.
Add your voice in our short CSAT survey!
