Hello guys,
we would like to switch from SVN to GIT in Codebeamer (v22.10).
Is there a way or best practice how to migrate existing SVN repository to GIT ?
thank you
Hi @MM_10991077 ,
These Codebeamer wiki pages might provide some helpful hints:
This one has a section called "Creating Bundles" at the end: Using Git with codeBeamer
And this one provides general knowledge on Managed Repositories, including creating them from a bundle/dump: Using Managed Subversion, Git & Mercurial Repositories (codebeamer.com)
Hi @MM_10991077 ,
Hi @MM_10991077
Is your question answered? If so, please mark the appropriate reply as the Accepted Solution. It may help many other users!
Of course, if you have more to share on your issue, please let the Community know so that we can continue to help you.
Thanks in advance!
