Setting "Any status" as a default in Downstream References Tab
PW_10729315
7-Bedrock
I have a question, is there any way to set "Any status" in the "Downstream References" bookmark in item as a default search value?
Right now, by default, cB is always showing only "Unresolved" items there:
As I remember, in older versions of cB (i.e. 21.09) there was a "Any status" option as a default option.
Yes, you are correct. This is fixed in the 3.0 version, and you will see this resolved there.
