Tracker Template
SM_10925308
Tracker Template
I created a tracker. Now i would like to reuse it in another project. I clicked on "available as template" box but when I create a new one, it is not available. Anyone does have same problem? Thank you!
Hi, after i checked "View If Owner"  in column "Created by" now is available! Thank you so much!
5 REPLIES 5
The "Available as Template" box is limited in scope and not meant for cross-project reuse. To reuse a tracker in another project, use Export Configuration > Import in the target project. Alternatively, for large-scale reuse, consider using a Project Template.
Shashi Preetham,
+91 8099838001 | shashi@psptechhub.com,
PSPTechHub  ||  World of PTC Thingworx  ||  LinkedIn
can you give me more info? I am on Admin tab and Ican just export Project or "ReqIF destinations"
Are you looking for the approach to reuse from the library? If so, please see: https://support.ptc.com/help/codebeamer/r3.0/en/index.html#page/codebeamer/user_guide/ug_req_lib.html
Hi there,
Did you checked, if the the tracker type is the same for the source and target tracker?
I.E. If you set an option "available as template" in source tracker of type "Bug", it will be visible on the list of available templates in destination tracker only if it's type is also set to "Bug"
