There is already another field with the same name/label
BB_Prince
3-Newcomer
There is an issue where deleting a field named “A” within a specific tracker and then trying to recreate a new field with the same name results in an error. How can I recreate a field with the same name?
Current Version : 3.0.0.2
Hi @BB_Prince ,
This issue occurs because when you delete a field in Codebeamer, it isn’t completely removed from the database — it’s only marked as inactive. The internal field key (technical name) remains reserved, so attempting to recreate a new field with the same name or label triggers the “already exists” error.
Here’s how you can resolve it:
  1. Check the Admin → Tracker Fields list.
    • Go to the tracker’s Admin → Fields page.
    • Enable the Show Deleted Fields option (if available).
    • If the deleted field appears, you can reactivate it instead of creating a new one.
  2. Rename the new field slightly.
    • If reactivation isn’t possible, use a variation of the name (for example, A_1 or A_New).
    • You can then rename it later once the old field is fully purged.
  3. Database cleanup (Admin-level only)
    • In older Codebeamer versions (such as 3.0.0.2), field metadata is retained until a background cleanup process runs.
    • Your system administrator can trigger a cleanup or manually delete the residual entry from the tracker_field table if supported.
In short, the name conflict is caused by the soft-delete behaviour — reactivating or waiting for cleanup is the proper fix.
Shashi Preetham,
+91 8099838001 | shashi@psptechhub.com,
PSPTechHub  ||  World of PTC Thingworx  ||  LinkedIn
Hello BB_Prince,
It looks like you have a response from a community champion. If it helped you solve your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
