Upgrading from Codebeamer 22.10-SP7 to Codebeamer 2
VM_11608121
2-Explorer
We are going update Codebeamer from 22.10-SP7 to Codebeamer 2. Do you have some ideas or walkthrough how to do that, because I can't find any information.
Thanks in advance
GVajda
(To:VM_11608121)
You can find the tested upgrade path document here: https://www.ptc.com/en/support/article/CS400089
Please also check the prerequisite requirements in Codebeamer release matrix pages here: https://support.ptc.com/cs/release-calendar/index.html
It is wise to do the upgrade first on your test instance.
GVajda
(To:VM_11608121)
Thank you for this information. I will read carefully upgrade path and will tell the results after upgrade
Survey Now Live!
Codebeamer Community: we're listening.
Add your voice in our short CSAT survey!
