Word export In Codebeamer-html ignore checkbok
SM_10925308
I am writing word template to export requirements from Codebeamer. My problem is about html. I can use "Ignore HTML formatting" in template parameters, but it deletes image and figure. Does it exist a solution to delete html formatting for the  text but that keeps image/table?
Other topic, in which file of Cb installation are defined the placeholder: item.id, item.description and so on?
Thank you
Hello @SM_10925308 ,
You cannot leave images and tables formatted. If you ignore HTML formatting, you will ignore it everywhere.
To get the list of the placeholders you can use this Word template: template-list-all-fields.docx (see attached)
Export the tracker with this template file, and the resulted document will contain the list of the placeholders.
Hello @SM_10925308,
It looks like you have a response on you topic. If it helped you solve your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
