As the installation guide,
support.ptc.com/help/codebeamer/r2.1/en/index.html#page/codebeamer/install_guide/5848463.html#wwID0EBRIKB
Minimum value of floatingLicenseSessionTimeout is 60min.
Minimum value of namedLicenseSessionTimeout is 1min.
I want to set floatingLicenseSessionTimeout = 5min.
Why is min. value of floatingLicenseSessionTimeout 60min?
Hi @I_S_PARK,
the floatingLicenseSessionTimeout and namedLicenseSessionTimeout is a built-in and mandatory setting and it must be used as the PTC Support help pages described.
When you would like to free up some floating licenses momentarily, we recommend to log out some users who are logged in with the floating licenses.
@I_S_PARK Did the question by @AndrasJ_hu help you? If so, please mark the appropriate reply as the Accepted Solution. It may help many other users!
Of course, if you have more to share on your issue, please let the Community know so that we can continue to help you.
Thank you so much, Jaime_Lee
