Since we were using Palo Alto VPN service and windows for connecting to company's servers when working outside the company and it was working ok
Now we started using Windows with Direct Access to remotely connect to the company server. Now the files on the server can be seen normally, but the Creo cannot connect to the license. The output is that Creo does not start.
When contacting support in our country, they said, that Direct Access is working on IPV6 protocol, which is not supported in current version of Creo 2.0 M120.
Please fix this!!!!
do you have found any solution?
br Bernhard
Hi!
cool - you could post the code in the posting.
br Bernhard
