creo viewer orientaion
mbrorsson
2-Guest
I have a problem when adding a new orientaion view.
It will not add the shown orientation only the default.
Thank´s in advance.
Mia
5 REPLIES 5
llie
(To:mbrorsson)
Mia,
Your Admin could have the view creation locked. Are you trying to get something like the attached image?
Before the values from the shown view were following when rotate model.
Now it´s stucked at default and has to be added manually.
As you can see from picture model_1 has the sam values as ISO 1 (default).
llie
(To:mbrorsson)
If you have admin rights on your computer you can just add it to the admin_prefs.xml in the loadpoint\preferences\Productview.
Add this in the code under this section  <preferenceList name="ViewOrientationsTable">
Change the last value line to the view name desired from "DEFTop" to "DEFXxxxxxx". You have to have DEF before the name.
      <preferenceItem>
        <preference name="locked"
                    value="false" />
        <preference name="IsXYZ"
                    value="true" />
        <preference name="DegZ"
                    value="-53.837" />
        <preference name="DegY"
                    value="14.008" />
        <preference name="DegX"
                    value="-18.324" />
        <preference name="OrientName"
                    value="DEFTop" />
      </preferenceItem>
Sorry but I don´t have this string, preferenceList name="ViewOrientationsTable"> in my ProductView_prefs.xml (creo viewer 3.0)
Thanks for the effort you making!!!
llie
(To:mbrorsson)
Send me your productview_prefs.xml to - and I will take a look at it.
