Good morning -
I have two users now who, after opening Creo and logging in to PDMLink get a blank white screen where their PDMLink window should be. If they open a second session of Creo and log in, PDMLink shows up as expected, and they can close the first session.
Any ideas? They aren't dead in the water, but the frustration level is high.
Creo 2.0, M110 / WC 10.1, M040
Thanks in advance -
Chrystal Johnstone
Red Dot Corporation
Seattle, WA
The following solved a white screen issue at my company. I am not sure it will solve your problem.
Ken Morrison
Medtronic/Covidien
Hi Ken,
Thanks for this workaround, it works for me.
I would still like to see a proper fix, having to do this every time the issue arises & restarting Creo isn't exactly ideal.
Could it be the cache size making problems? Might be worth it testing increasing/decreasing this.
//Torben
Hi Ken,
Could you add some screenshots? I can't find the 'Command Search field', where 'Browser Options' has to be typed in.
Thanks in advance, Hugo.
<< ProE WF5 - PDMLink 10.1 M040>>
Hugo: I think the command search is a Creo invention, not available in ProE WF5.
But I'm pretty sure the Browser Options work about the same, it's just a matter of finding it... 🙂
Good luck.
//Torben
According to https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS168586 this has been fixed in Creo 2 M120 and Creo 3. I see you were on M110. We've just updated to Creo 2 M150, from M110. No issues yet, but it hasn't been long enough to call it resolved.
Good afternoon
I know that this is an old post but for us, we always got white pages if, in the previous session the user opened 2 Creo sessions.
It seems that Creo doesn't like to be connected to the plm and to have two session opened at the same time.
tip : I solved this killing the XTOP.exe 😞
I have tried the solution to empty the Offline storage, and it's works after a refresh of the browser page!
thanks for this new tip!
Véronique
