3D Scanner
csheakoski
3D Scanner
I was basically just wondering if anyone out there has any experience with a 3D scanner that works well with Pro/E. If you have any suggestions or experience I would like to hear about it. My company is starting to look in to one and would like some suggestions. Thanks.
2 REPLIES 2
Go for GOM ATOS/TRITOP scanner, very good one. If you want to use to full extent then you may have to go for PRO E Reverse Engineering modules. Thanks & rgds Krishna Kumar.K.K
Not applicable
(To:ptc-809412)
Hi, You can look for Euroform, or creaform... I think it will be an interresting way...
