I am using CREO 2.0 M090 on windows7 64bits, and I just installed ANSYS 15. maybe I should mention that I also have Wildfire 4.0 installed on the same computer. The problem is that the CAD interface between ANSYS Workbench and CREO does not work. I've been following all the steps described on Ansys customer portal, and still no success. before contacting Ansys support, I would like to know if others CREO 2.0 are encountering the same problem, or if I'm simply doing something wrong. I've been trying a lot of stuffs to make it work, so rather than a "It should work if you do..." I wish I could have a " I did.......and It's working Fine for me" kind of answer.....still, all advices are welcome....
Stephane
Hi Stephane,
ANSYS 14.5 supported for Creo 2.0 M050 and above, refer Platform Support at
http://www.ptc.com/WCMS/files/135225/en/creo2_hw_notes.pdf
Possibly you may need to contact ANSYS Support for if it works.
Mahesh
Hi Stephane,
Mahesh
