I want to use thewildfire 3.0 pro/efeature"Automatic scaling to fit the model inside the space defined by the template view boundary". I am able to drag a view boundary in the template mode but not able to add a model to this viewto automatically scale the model to fit in that boundary.
Can anyone help me with this please?
Chandana
Hi All,
Here'showautomatic scaling works:
1) Create a New drawing and in the new drawing window select a template or selectempty with format and specify your format.
2) Then goto "Applications" in the Menu bar and select "template" mode. Then goto Insert-->Template View which opens up a "template view instructions" dialog box. Give whatever orientation you want under the view values for View States.You can give a saved orientation too. Then select place view and depress left mouse button and draw a boundary on the template. Now save thisas a template. We can't place a model directly on this.
3) Next time when creating a drawing, select this particular template which you saved and it will automaticallyplace the model to fit in that boundary of the template.
Chandana
