CAM Software for ProE
engineering2
Right now we are using Mastercam for CAM, but we are looking for a CAM software that integrates with ProE, so that we can eliminate file translations. I know of Pro-NC and Hypermill. Are there any other good packages available? And does anyone have any experiences with these, good or bad?
6 REPLIES 6
Hello, As I heard from my colleagues, ProNC is one of the best CNC module. There is also the Vericut module to check your toolpaths, ...
Hello I user of Pro/NC, for me that is best, but I am learning. If your hear anything, let me know, send me please. Thanks & Regards
I use GibbsCAM with Pro/e files though you need to purchase the Granite translator module from them. They are beefing up their surfacing routines for a fall release of GibbsCAM 2008, which will put the capabilities more in line with Pro/NC.
Not applicable
(To:ptc-525826)
I suggest learning and utilizing ProNC as a cam package. Pro NC will ave a little higher learning curve since it resembles the file architecture of Pro E 2001, but if you are considering keeping with Pro E as a cad packege this can't be beat. You can keep part and tool paths parametric, without any loss of translation.
ptc-1010422
(To:)
Model translate the painful experience for all users. And if you are doing frequent prototyping by modify the model, trail-and-error (generally it is a product R&D/research and development steps)and fine tune the output, packaged ProNC with the proE is the only choice if you use ProE as the design module. Ten years ProE/ProMFG player.
