CREO 2.0 M060 vs. EFX7.0 M010 Compatibility ?
Dante
7-Bedrock
is it possible to plug EFX7.0 M010 to CREO2.0 M060 ?
AndyHermanson
(To:Dante)
May i ask why you would want this instead of using AFX? It is part of the install package if you select it. Then you just turn it on with the AFX_ENABLE config.pro option.
Problem solved,
crazy mistake ... according to installation manifest AFX is optional package and by default it is not installed.
so after AFX_ENABLE Yes i got "EFX fail to Load" message. i misunderstand the problem and just was looking for some alternative solution.
thank andrew
AndyHermanson
(To:Dante)
Glad i could shed some light on it for you.
