Can't blank vertical line which divides columns in a table -- Solution
marcstewart63
I have a solution thanks to Mike D. from Synthes, he came through with the solution first. Thanks to all of the others who also suggested the same thing! J
I missed the obvious pick, You must select the entire table first before the Line Display command becomes active.
Thanks Mike for the tip!
BWC
Marc
0 REPLIES 0
