Can you make Proe not create a trail file?
rcrisp
Proe Users,
Ryan Crisp | Senior Mechanical Engineer
Priority Designs
501 Morrison Rd.
Columbus, OH 43230
(614) 337-9979
www.prioritydesigns.com
9 REPLIES 9
mlocascio
(To:rcrisp)
That's an interesting question. I suppose that there is a reason for this
question.
Michael P. Locascio
dgschaefer
(To:rcrisp)
I don't think so. Why do you want to?
Doug Schaefer
LinkedIn
gkbeer
(To:rcrisp)
Set the trail file directory to one that does not exist.
On Monday, November 28, 2011, Doug Schaefer <>
wrote:
> I don’t think so. Why do you want to?
> Doug Schaefer
Is there any /dev/null to windows??? 🙂 🙂 🙂
does any UNIX user set the trail file directory to /dev/null ??
(just kidding 🙂 🙂 )
-nk/.
BenLoosli
(To:rcrisp)
Doesn't work. The trail file is still written to either the start-in folder or the folder above the non-existent one.
Thank you,
Ben H. Loosli
USEC, INC.
DonSenchuk
(To:rcrisp)
I don't think so.
A quick work-around...
1. Create a folder that the trail files will be directed into.
2. Create a batch file to delete all files from that folder.
@del /S /Q /F "C:\<folder path=">\*.*"
3. Create a scheduled task to run the batch file daily.
This will permanently delete anything placed in that folder at the scheduled time.
In Reply to Ryan Crisp:
Proe Users,
Priority Designs
501 Morrison Rd.
Columbus, OH 43230
(614) 337-9979
www.prioritydesigns.comhttp://www.prioritydesigns.com
We are using Intralink 3.4 so it may be different for you, but I just
modified the Intralink startup batch to delete the trail files and copy
configs etc. That way it deletes the existing trail files before Pro/E
starts.
Nathan Zimmerman
Product Development Coordinator
PTC Systems Administrator
Engineering
1000 Buffalo Road
Lewisburg, PA 17837 USA
gkbeer
(To:rcrisp)
/dev/nul is a UNIX thing.
In windows its just NUL.
TRY: Trail_file_dir NUL
dgallup
(To:rcrisp)
In a config.pro file set your trail directory to some local directory, I use:
trail_dir $temp
Then in the bat file that starts Pro/E I add these two lines to the bottom of the file:
cd /d %TEMP%
G:\Apps\PTC\proeWildfire4M170\i486_nt\obj\purge.exe
This leaves two trail files, the one you are currently writing and the previous one.
PTC quality philosophy: We've upped our quality standards. Up yours.
