Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
Does anyone know what the command Pro/E is expecting from the middle mouse button so I can program a custom mouse? It's probably obscure but I'm throwing it out in case anyone knows. Thanks.
