Connecting two sketches...
nsrivastava
I wanted to joing these two sketches what tool should I use.....Is there any tool similar to loft.
Did you try boundary blend?
8 REPLIES 8
I selected both sketch in boundary blend but it is not working. Any suggestion how to do it.
A surface is created how to convert it into solid.
You can create a fill feature for both the top and bottom.
Then merge the 3 surfaces into a single quilt.
You can then Solidify the quilt.
Thanks a lot with your assistance I was able to create the required model. The finished model with rendering in Autodesk Inventor is below. I am not good in rendering in Creo hopefully in future I would learn it.....Well thanks a lot once again....
Happy I could help. Looks great!
As I said earlier I was able to create the model but one thing is more required, that I was able to do in other CAD application . Deformation in model as affected by using an opener....Bending a part along a line option in Creo if so how can it do it. ...
Creo has a warp feature for this, and a more advanced Spinal Bend feature.
