I have WF4 M040 loaded. I just installed M060. When I start M040 I have no problem but when starting M060 I receive anwarning message:
Windchill cache must be converted to 2008 format.
Press OK to convet, Cancel to exit application.
We are still use WF3 but I am looking at WF4. Did anyone else receive this error and will it present a problem for me when going back to WF3? Would I not recieve this error if I deleted all my workspaces and the PTC directory on my computer?
Steve G
Chris R provided the answer.
I renamed the PTC directory from WF3in my profile but I still received the error. He suggested using the PTC_WF_ROOT environment variable.For thosethat do not know this is usedto set thedirectory somewhere else instead of the default C:\Documents and Settings\<username>\Application Data\PTC.
My problem was that I already had that in my startup script but forgot about it. I wanted to make sure I did not mix my WF3 files with WF4. Once I deleted the directoriesWF4 created (.Settings & .cache2008) in the other directoryI did not receive the message any more. WF4 also creates a couple files .lock & .wfwsi2008. I deleted them too just in case.
Steve G
