Is there an easy way to create a chamfer with a constant width?
I would like to control the distance from edge to edge of a chamfer between varying surfaces.
For now, you probably have to leverage the new capability of rounds in Creo 3.
Use the round as a surface and use its edges to guide a sweep/cut as a variable section sweep.
