Hello I need to create the auger that i have attached. I can do the spiral and the straight piece going down the center of the spiral. But connecting the two is a problem If anyone can help that would bee great I am using Creo3.0
Try a datum curve through points; you should be able to make the ends tangent to the helical curve and the straight line curve.
