Creo 2.0 Startup script
vmcdaniel
I'm working on my Creo Parametric 2.0 startup script. M010, WIN 7 x64.
My plan is to launch parametric.exe, which loads parametric.psf. In the PSF, I RUN my BAT file to standardize.
Any drawbacks you can think of.
For Pro/E I run a BAT, which standardizes, then calls proe.exe, so this is a little different than that, which makes me ask the question.
The advantage I found is, this allows users to PIN parametric.exe to the taskbar and retain a Start In directory.
BTW, is there an ENV VAR for the start-in directory?
Thanks!
-Vaughn
Thanks for all the direct replies.
No one really baulked at the use of the PSF file to call RUN the BAT file. I think it is a great idea because it allows you to launch Creo from the default icons/exe file and then configure the session using the PSF chooser running different BAT files.
[cid:image001.png@01CD6588.A314A810]
If you want to make your BAT Pin-able, Brad Sessions has this tip:
I start Pro/E with a bat file and was unable to pin the shortcut to the taskbar until I added the following (red) to the Properties before the bat filename:
Target: C:\Windows\System32\cmd.exe /c C:\ptc\ProE_Agile_CO.bat
Start In: C:\ptc\pro_work
-Vaughn
Vaughn,
Did you try this? It's under the "customize" button in the reconfigure.exe program (used to be called PTCSETUP.exe) in your BIN directory.
[cid:image002.png@01CD659D.E99C0700]
[cid:image001.png@01CD659D.C85F44D0]
Bob Schwerdlin
Design Engineer
Dukane Corp.
