Creo 2.0 Startup script
I'm working on my Creo Parametric 2.0 startup script. M010, WIN 7 x64.
My plan is to launch parametric.exe, which loads parametric.psf. In the PSF, I RUN my BAT file to standardize.
Any drawbacks you can think of.
For Pro/E I run a BAT, which standardizes, then calls proe.exe, so this is a little different than that, which makes me ask the question.
The advantage I found is, this allows users to PIN parametric.exe to the taskbar and retain a Start In directory.
BTW, is there an ENV VAR for the start-in directory?
Thanks!
-Vaughn
Thanks!
-Vaughn
