Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
I need to clarify myself, I do have the arrow cursor for the most part,its when I choose create a dimension my cursor shape turns into a pencil shaped cursor in which I do not like that,I would prefer it to stay with the arrow at all times . Any ideas or is it possible?
