Curve Error
DieselPig
Curve Error
Morning All
This weird! Had this error this morning and somehow it mystically cleared, now its back!
Any ideas how to clear, it look OK to me.
9 REPLIES 9
MichalLukac
(To:DieselPig)
in creo3 M120 without error...
Interesting!
We have Creo 3.0 M090
MichalLukac
(To:DieselPig)
Have You tried to play with accuracy setting?
There is in Your model 0.0001, I tried to set to 0.001 but it allows only values from 0.005 to 0.5. I set 0.005 and regeneration fails on Trim 6 feature.
Now I cannot return accuracy back to 0.0001.
Hi Michal
Tried that with the same result, Trim 6 fails.
If I knew what the actual problem was I could try and fix it!
OK after a bit of re-arranging that error is fixed!
Next issue, quilt F46 & F27 won't merge!!
MichalLukac
(To:DieselPig)
May be sketch 4 causes the problem. look at it, why is it so ugly constrained?
Hi Michal
That's just the way it was sketched against the reference. When I select Tools-> Geometry Checks there are no errors. Can't see how that can affect the merge or can it?
MichalLukac
(To:DieselPig)
I don't know but if look at the model there are some holes os small surfaces and may be the F46 and  F27 don't connect or intersect.... I think the bottom of the blade should be coincident with the plate
Hi Michal
Yes, found the errors and fixed them. It was trimming off the whole face and I did not see it.
