Date in skecth
Daniel_Rendon
Date in skecth
I need to write the date    /MM/YY in a sketch in Creo Parametric 2.0.
I use the Text tool.
I need to update automatically this date every time that i open the file.
I know... I can use a parameter from the model parameter list, but i don´t know how to create a parameter with the actual date and always update it.
Anyone knows how to do this?
Thanks.
2 REPLIES 2
TomU
(To:Daniel_Rendon)
Nope.  No can do.  Creo doesn't have a way to read the current date and time.  The closest you can get is todays date on a drawing, but it only evaluates one time - when initially created.  If you are connected to Windchill, then you can get a parameter that displays the last time a file was saved.  See Note in drawing with time information 12-12-2012 12:12 PM for a similar idea.
Use Pro/Program and prompt the user to enter the date.
