Default Text Size
ptc-1430243
Default Text Size
How do you set the default text size to be .19 at all times?
2 REPLIES 2
you have to set it in the drawing setup file usually.
Your config.pro should have pro_dtl_setup_dir and enter a location as your value like $PROSTDS\dtl it should also have a drawing_setup_file like $PROSTDS\dtl\config.dtl, make sure that you change the drawing_text_height in your config.dtl
