Default template
A.DelNegro
7-Bedrock
Default template
Is there a way to uncheck 'Use default template'? This used to not be
on, and I'm not sure what I did to turn it on, but I can't find what I
need to change to turn it back off. Anyone?
Tony
2 REPLIES 2
Thanx Mark for the quick comeback.
No thanx PTC for the completely OBVIOUS setting name.
T
Config.pro option force_new_file_options_dialog yes will gray out the check mark box
David Brainsky
Chula Vista, Ca. 91910
