Community Tip - If community subscription notifications are filling up your inbox you can set up a daily digest and get all your notifications in a single email.
X
How do you change the default text size to .19? It is .156 now and after I am finished with a detail I have to change all dimensions. Thank You in advance.
hi Daniel Yoder, In drawing option>sort>By category.. then there is option contol text.U can set there HEIGHT,WIDTH,THICKNESS of text... regards, shailesh
