Default text size
danyoder50
Default text size
How do you change the default text size to .19? It is .156 now and after I am finished with a detail I have to change all dimensions. Thank You in advance.
2 REPLIES 2
hi Daniel Yoder, right click on drawing then properties>Drawing options>there is options for controling text size. Regards, shailesh
hi Daniel Yoder, In drawing option>sort>By category.. then there is option contol text.U can set there HEIGHT,WIDTH,THICKNESS of text... regards, shailesh
