Dialog box opening behind main window
Am I the only one, or do others have it where the dialog box (i.e. when you do a Save As, Edit text, or other things that require a pop-up box) opens behind the window you are currently working on. Sometime I'll wait for a short while for it to open, only to do an Alt-Tab and find it has been open waiting for me. It just opened up behind the window being called from instead of above?
Dale
