Dimensional Accuracy in Sketcher
ptc-2781586
I had created a model with Pro-e relations.when I am giving value, it is not accepting, if the entered value is +/-0.1 then the set value in relations & giving me error like geometry overlap. In Options, geometrical accuracy is set upto 4 digits. How can I solve this problem???
my email address is - Please help me to solve this problem Thanks in advance.
38 Views but no reply....Does all friends understaing my question or Is it confusing? Please help in solving the problem.
if the error is "geometry overlap" that means there is some problem with the model.The value you are entering is causing your model to fail. Check the relation you have entered in the model
It might also help to know what the geomtery you are creating is.
