Dimensioning Problem
ayaqoob
i 'm beginner.. facing a problem regarding dimensions.. they initially appear as
SN1.JPG perhaps these are in mm. i want to use inches, i went here SN3.JPG they are already in inches.. i changed to others settled them back to this but no avail.. they keep appearing the same way.. i want to work with inches in single digits but when i type in 1,2 thing appear in micro..nd i guess they show 1mm,2mm etc not inches...while by default creo is set to inches.. i 've creo 3.0 M020 educational edition
measure edge of your model to see lenght units.
Martin Hanak
Martin Hanák
Martin Hanak
Martin Hanák
i got that..but what should i do so as to work with smaller values, the lines,arcs etc appear too small.. If i zoom in while working 1st it does not present an appropriate interface plus when i complete an operation nd hit the check mark it switches to normal nd things appear too small.. in short how can i change relation b/w on screen length and actual length?
Ahmad,
please, next time upload some explaining pictures.
Default display is affected my datum geometry display.
Model without offset datum plane
Model with offset datum plane
Martin Hanak
Martin Hanák
