Disk Error
vborase
Disk Error
Creo 3.0 Parametric Showing pop up massage "Error writing file ; check disk space or write permission"
2 REPLIES 2
this probably means that you do not have full access rights to current working directory. Set Start in field in Creo startup shortcut to %TEMP% and try again.
MH
Martin Hanák
Mahesh_Sharma
22-Sapphire I
(To:vborase)
Vinayak,
Which datecode of Creo 3.0? AND when you are getting this error?
