Display of a variable and the value corresponding to it
VladimirN
As it is possible to display in a graphic window (in a mode 3D) the following information: the geometrical values together with parametres corresponding to them. For example: d1 = 500 mm?
1 REPLY 1
The answer to this point in question can be found here:
http://communities.ptc.com/blogs/vpalffy/2011/02/28/create-driving-dimension
