Distance between axes and planes
ptc-2238944
I am a user of Autodesk Inventor and started with the Pro/E.
Can I put distance between a axes and some plane (similar Autodesk Inventor)?? or I have to create planes and align them ??
2 REPLIES 2
Actually I need in Component Placement add constraints between some part_axis, "A_9" and some plane of my assembly, "F5 (WALL SURFACE)".
I can do this using a datum point, or creating planes, but I guess it's expend many time to do.
Filipe Everly
Belo Horizonte - Brazil
No, unfortunately you cannot constrain an axis to a plane. It would be
nice, but it isn't possible now. You'll need to create some other
geometry.
Doug Schaefer
LinkedIn
