EXT : Reference Dimensions
ptc-141274
It turns out there is a standard icon that will toggle the reference dimensions!
It's called Annotation Element Display. If it is not on your menu, it is under the VIEW section when go into to customize your icons.
Thanks to Tony for this information.
Doug
[cid:image001.png@01CBFF6B.61DCB970]
The only drag about having to use this icon is that it also shows every screw hole annotation on your part or assembly. That SUCKS !
Only in Pro/E WF 5 are you required to do this. Prior to WF 5, all you needed to do was choose the datum plane and select your references and it would show right away - no need to show screw holes as well. This is yet another WF 5 step backwards, along with the entire drawing mode "enhancement".
Bob
mlocascio
(To:ptc-141274)
Well, that is really cool to know. Thanks!
Michael P. Locascio
