Edge Selection
  • December 14, 2009
  • 1654 views
I am trying to figure out how to select convex edges of the same length. I make fixtures out of .250" plate. I would like to be able to select the convex edges that are .250" in length in order to round them. Is it possible to do this without selecting the edges individually? Thanks, Brian
    Try query-selecting one such edge, then cycling through the list to any Intent Edges that appear. This may be a partial solution.
    Don't know if this is your issue or if the following will be helpful. What I often do if I have a relatively thin part that needs its shortest edges rounded is temporarily increase the thickness of the part so that the edges are much easier to select. Actually, most of my plate-type parts start from an already created 1x2x3 block, and if I know the corner edges are to be rounded, I do that before changing the dimensions to what I want.
