Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
Trying to create a curve using 2 or 3 edges of a square. Works for 1 or all edges. When I pick 2 or 3 edges the copy command is grayed out. What am I doing wrong? Using Wildfire build 240.
