Enhanced Realism and Rendering
NEALROSENBLUM
All,
How do I make my model appear as if it is floating above the floor with a shadow? All of my renderings currently show my models on the floor with reflection.
(Wildfire 5.0)
TIA.
Sincerely,
Neal Rosenblum
Geometrix Engineering, Inc.
201 N. 13th Avenue
Hollywood, FL 33019
Ph: 954-920-2049
Fax: 954-920-9574
Cell: 954-649-9399
neal@geometrixeng.c
1 REPLY 1
If you enter the render room, you can move the floor up or down to the desired distance. Make sure you have shadows turned on in your Render Setup.
This should work.
"Too many people walk around like Clark Kent, because they don't realize they can Fly like Superman"
