The 3D PDF is very convenient since it works with the ubiquitous Adobe Reader, but the file size seems to be much larger than for theCreo Viewer. If you'll be transferring files, check out the file size first.
Creo View has
How does the file size compare between E-drawings and Creo View (and 3D PDF, for that matter). Do they handle various geometry more or less efficiently during publishing or opening?
Ok, I did an informal comparison. See the attached table for a comparison of file sizes.
For the comparison, I used a convenient part and assembly from Creo Elements/Pro 5.0. I saved it in 3D PDF format and Creo View format. I also saved it as a STEP file for comparison. I then opened the native .prt and .asm files in E-Drawings and generated .eprt and .easm files. E-Drawings took a long time to open the assembly, but the resulting file sizes were amazingly small.
I then generated an STL file from a Creo Elements/Pro model. I was using Creo View Express (2.0) so I couldn't open the STL file and export to pvz. E-Drawings (Professional 2012)did this quickly and produced a small .eprt file. I don't know what options might affect the file size for any of these viewables during generation. If anyone has other insight, I'd be interested.
In Reply to Steve Barnhart:
