That is funny because I just sent an enhancement request to PTC. The
config option chamfer_45deg_dim_text set to asme/ansi, ( or
default_chamfer_scheme) does not work correctly or not per ASME
standard, per asme it should be dim X angle, so PTC has the wrong
functionality and are not conforming to the standard that they are
calling out.
As far as I know everybody has to change the chamfer dimensions.
We should all try to create an enhancement request for this option, as
you know, the squeaky wheel gets the grease.
Jael B. Aldebot-Brousseau
Designer, Opto-Mechanical Engineering
BAE SYSTEMS
Communication, Navigation,
Identification and Reconnaissance
450 Pulaski Road
Greenlawn, NY 11740
*Tel. (631) 912-2799
Fax (631) 912-2721
*Email jael.brousseau @baesystems.com
Confidentiality Notice: This message is confidential. The information
contained in this message is intended only for the personal and
confidential use of the recipient(s) named above. If you are not the
intended recipient, please do not read, copy, or use it, and do not
disclose it to others. Please notify us immediately by telephone of the
delivery error and returning the original message to us via mail.
