Getting item ids of edge vertices
pseetharam
Is there a way to get the item ids of the vertices of an edge?. I have a ProEdge object, and I want to get the ids of it's 2 vertices so I can init them as ProModelItem(s).
I know I can do this if I route it through a ProSelect call (ask the user to select a vertex) and then get the model item with a subsequent ProSelectionModelitemGet call, but I want to do this without any user interaction.
Thanks.
-Pradeep
2 REPLIES 2
Pradeep,
Read the API Wizard under User's Guide->Geometry->Visiting Geometry
Objects->Visiting Solid Geometry->Visiting Datum Points. This will
allow you to get a handle to a Datum Point so you can retrieve the Id.
Basically you need to call ProFeatureGeomitemVisit on your ProEdge
object and visit PRO_POINT objects. Remember that a point will be
visited twice if it is shared by two edges (just an FYI if you want the
distinct points).
Patrick Williams | CAM Systems | Steelcase Inc. | 616.698.4078
Dang, I knew and should have seen that. Got sidetracked trying to figure how to get a PRO_EDGE_START/PRO_EDGE_END types from an edge.
I guess I can visit the points, cast it to a model item and check it's type, OR do a simple uv eval of it's coordinates to see if the point is the start or the end vertex.
Thanks for the heads up about the double visitation for shared vertices.
