HP Plotter
jjakubos
HP Plotter
Brent,
Thanks for the reply. You were one of two replies. We rarely use the
plotter for CAD work these days also. Must be no one else is even
carrying a plotter any more. I think we would not except for the
miscellaneous plant use.
I'll let you know what we find with the T790.
On a separate issue. We are considering an update from WF3. My
question is to what? Is there significant advantages to Creo parametric
over WF5 (unsure of the correct notation here)? Can an argument be made
to stay with WF3? I don't mind using old tools so long as they do what
is required efficiently.
Jim Jakubos
Rexair LLC
Project Engineer
0 REPLIES 0
