Mass properties - HTML file only?
KrisR
Please tell me that there is another way to save the output from mass props other than an HTML file? Text file at least? Word doc? Excel?
Thanks!
mjenkins
(To:KrisR)
Haven't ventured above WF4 but:
Analysis>Model>Mass Properties>Select Coordinate System>Cut & Paste into Mass Props.txt?
In Reply to Kris Rowlands:
Thanks!
Chris3
(To:KrisR)
Analysis>Model>Mass Properties>Select Coordinate System>Click the blue
"i"-> File->Save as
Chris
This communication, including any attachments, consists of non-public
information that is intended solely for use of the individual or entity
to which it is addressed. It is a confidential communication that may
contain information that is proprietary, privileged, export-controlled
and/or exempt from disclosure under applicable U.S. and non-U.S. law.
If the reader is not the intended recipient, or agent responsible for
delivering the message to the intended recipient, please notify the
sender immediately by reply e-mail and delete the communication,
including any attachments, from your system without saving any
information or making any physical copies. Unauthorized use,
dissemination, distribution or copying of this communication, including
any attachments, is strictly prohibited.
