Can some on help me i whant 2 use comma when i enter values in creo. now i can only use dot like (45.25) i whant it 2 be metric (like 45,25)
I have search for its bot no resualt.
the closest i have come is decimal_marker bot it dossent work.
Morten,
if you set drawing option decimal_marker comma then Creo will display comma character in dimensions shown in Creo drawing.
If you type a value on the keyboard you have to always press period key.
Martin Hanak
So if i unterstand right.
I cant when im using Creo 2 use comma when i enter a value in a sketch? there is simply no option that makes the comma work?
an eksemple
i have a line i whant 2 be 25,6 mm, i cant enter 25,6 (comma) coz creo 2 only accept 25.6 (period key)
this is so stupid.. relly
Commas are only used on drawings so the period doesn't get lost in document replication.
There is no mathematical requirement that data be entered using the comma.
You don't type values 1,000.00 with a comma either, do you? And how would you differentiate 1,000,000 from 1000,000 (1000.000)?
-That- is how you can miss mars by a million miles
Morten,
you understand me right...
Martin Hanak
Bump bump bump.
Has this been changed in Creo 3.0? I am really annoyed with this as well as it leaves me with an inefficient use of my keyboard.
